Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 2
Loosen the nuts holding the axle in the wheel using the wrenches. Unscrew the axle, and remove the bearings and brake assembly. Set them off to the side on a rag. When pulling the parts out, arrange them in the order in which you took them out. This way, you don't forget the order. When pulling the parts out, arrange them in the order in which you took them out. This way, you don't forget the order.
  • Loosen the nuts holding the axle in the wheel using the wrenches. Unscrew the axle, and remove the bearings and brake assembly. Set them off to the side on a rag.
  • When pulling the parts out, arrange them in the order in which you took them out. This way, you don't forget the order.
Hier Übersetzung einfügen
