Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench. After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side. If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
  • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
  • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
  • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
  • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
  • Make sure you don't raise quill stem above minimum insert line.
Hier Übersetzung einfügen
