Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 6 übersetzen
Schritt 6
Locate the battery cables and the tip of a plastic spudger or opening tool to gently push the connector head out of its socket. Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
  • Locate the battery cables and the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
  • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
  • Be sure to not have any water around the device while removing the battery.
  • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
Hier Übersetzung einfügen
