Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly. Be sure to only apply pressure to the casing panels and not the sensitive internal electronics. Once the rear housing is separated, the settings buttons will be accessible for replacement.
  • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
  • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
  • Once the rear housing is separated, the settings buttons will be accessible for replacement.
Hier Übersetzung einfügen
