Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 14 übersetzen
Schritt 14
LG Watch Urbane Repairability Score: 7 out of 10 (10 is easiest to repair) Once you're inside, the motherboard is very easy to remove—three Phillips screws and a few connectors.
  • LG Watch Urbane Repairability Score: 7 out of 10 (10 is easiest to repair)
  • Once you're inside, the motherboard is very easy to remove—three Phillips screws and a few connectors.
  • With the motherboard out, the battery is very easy to replace; only mild adhesive holds it in.
  • Features a standard 22 mm band secured with spring bars—replacement and style swaps are easy.
  • Glued back requires heat and prying to open, and replacement adhesive to properly re-seal.
  • Because the display is adhered to the back of the front glass, which is removed from the front, screen replacement is very difficult and will require re-adhering the display layers.
Hier Übersetzung einfügen
