Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Lay down the display with screen side up. Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base. Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
  • Lay down the display with screen side up.
  • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
  • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
  • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
Lege das Display mit der Bildschirmseite nach oben ab.
Der Standfuß ist beweglich. Deswegen ist es gut, wenn du das Display mit einem Hartschaumblock gegen den Fuß abstützt.
Bringe die Saugheber auf beiden Seiten oben fest am Bildschirm an.
Die Glasscheibe ist am restlichen Bildschirm mit kleinen Magneten befestigt. Hebe langsam an, bis sie sich ablöst.
[* black] Lay down the display with screen side up.
[* icon_note] Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
[* black] Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
-[* black] The glass screen to connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
+[* black] The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
