Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary. You may want to only take the tabs half way off to avoid re-gluing when reassembling. Remove the three T6, 7.0 mm screws under each rubber tab.
  • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
  • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
  • Remove the three T6, 7.0 mm screws under each rubber tab.
  • Because the screws are a different length, set the screws aside.
Hier Übersetzung einfügen
