Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Remove the two 1.5 mm screws using a Phillips #00 screwdriver securing the battery connector to the motherboard.
  • Remove the two 1.5 mm screws using a Phillips #00 screwdriver securing the battery connector to the motherboard.
  • Use a spudger to gently pry up the battery connector from its socket.
  • Do not apply pressure to the socket.
Entferne die beiden 1,5 mm Kreuzschlitz Schrauben, die den Akku an der Hauptplatine befestigen.
-[* red] Remove the two 1.5 mm Phillips screws securing the battery connector to the motherboard.
+[* red] Remove the two 1.5 mm screws using a Phillips #00 screwdriver securing the battery connector to the motherboard.
+[* black] Use a spudger to gently pry up the battery connector from its socket.
+ [* icon_caution] Do not apply pressure to the socket.
