Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
Using the tweezers, carefully lift up the tape covering the electrical strip  as shown in the picture. Be gentle when lifting the tape as it  can tear easily. Use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
  • Using the tweezers, carefully lift up the tape covering the electrical strip as shown in the picture.
  • Be gentle when lifting the tape as it can tear easily.
  • Use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
Ziehe mit der Pinzette vorsichtig den Klebestreifen ab, der das Kabel bedeckt.
Sei mit dem Klebestreifen vorsichtig, er kann leicht reißen.
Verwende einen Plastikspatel, um den ZIF-Stecker zu lösen.
-[* black] With the tweezers, carefully lift up on the tape covering the electrical strip shown in the picture.
-[* icon_caution] Be careful with the tape, as it can tear easily.
-[* red] Use a spudger to disconnect the ZIF connector.
+[* black] Using the tweezers, carefully lift up the tape covering the electrical strip as shown in the picture.
+ [* icon_caution] Be gentle when lifting the tape as it can tear easily.
+[* red] Use your fingernail or a spudger to lift the hinged retainer clip on the ZIF connector and slide the cable out.
