Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6
Remove the dual LED flash cover with a pair of tweezers. This is held on with a small amount of adhesive. Using a mildly heated pair of tweezers would ease the removal of flash cover as it helps weaken the adhesive . Remove gently as the flash cover may be glued to the antenna cable(s) below.
  • Remove the dual LED flash cover with a pair of tweezers. This is held on with a small amount of adhesive.
  • Using a mildly heated pair of tweezers would ease the removal of flash cover as it helps weaken the adhesive .
  • Remove gently as the flash cover may be glued to the antenna cable(s) below.
  • Use a pair of tweezers to disconnect the two antenna cables near the camera.
  • Some models of this phone will have only one antenna cable at this location.
  • Proceed to disconnect the antenna cable near the bottom right of the phone.
Entferne die Abdeckung der beiden LEDs.
Entferne mit einer Pinzette die beiden Antennenkabel.
-[* black] Remove the dual LED flash cover.
-[* red] Use a pair of tweezers to disconnect the two antenna cables.
+[* red] Remove the dual LED flash cover with a pair of tweezers. This is held on with a small amount of adhesive.
+ [* icon_note] Using a mildly heated pair of tweezers would ease the removal of flash cover as it helps weaken the adhesive .
+ [* icon_caution] Remove gently as the flash cover may be glued to the antenna cable(s) below.
+[* orange] Use a pair of tweezers to disconnect the two antenna cables near the camera.
+ [* icon_note] Some models of this phone will have only one antenna cable at this location.
+[* yellow] Proceed to disconnect the antenna cable near the bottom right of the phone.
