Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
The fan is connected to the main logic board by two connectors. Make sure that while disconnecting them, grab the wire at the point closest to the board and the  pull slowly to avoid damaging the connectors. Remove the piece of tape that is holding the wires to the casing. Remove the piece of tape that is holding the wires to the casing.
  • The fan is connected to the main logic board by two connectors. Make sure that while disconnecting them, grab the wire at the point closest to the board and the pull slowly to avoid damaging the connectors.
  • Remove the piece of tape that is holding the wires to the casing.
Der Lüfter ist am Logic Board mit zwei Steckern angeschlossen. Fasse die Stecker beim Ablösen so nahe wie möglich am Board an und ziehe sie langsam heraus, damit sie unbeschädigt bleiben.
Entferne das Klebeband, mit dem die Kabel am Gehäuse befestigt sind.
