Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Remove the two 1.5 mm screws using a Phillips #00 screwdriver securing the battery connector to the motherboard.
  • Remove the two 1.5 mm screws using a Phillips #00 screwdriver securing the battery connector to the motherboard.
  • Use a spudger to gently pry up the battery connector from its socket.
  • Do not apply pressure to the socket.
Entferne die beiden 1,5 mm Kreuzschlitz Schrauben, die den Akku an der Hauptplatine befestigen.
[* red] Remove the two 1.5 mm screws using a Phillips screws#00 screwdriver securing the battery connector to the motherboard.
[* black] Use a spudger to gently pry up the battery connector from its socket.
[* icon_caution] Do not apply pressure to the socket.
