Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 5
Peel back the Kapton tape from the remaining three ZIF connectors, then use your fingernail or a spudger to lift the hinged retainer clips on the ZIF connectors and slide the cables out from each. The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath. The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
  • Peel back the Kapton tape from the remaining three ZIF connectors, then use your fingernail or a spudger to lift the hinged retainer clips on the ZIF connectors and slide the cables out from each.
  • The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
Löse die drei verbleibenden ZIF-Stecker.
Der dritte ZIF-Stecker liegt hauptsächlich unter dem Motherboard. Achte beim Wiederzusammenbau darauf, dass der Stecker wieder genauso liegt.
[* black] DisconnectPeel back the Kapton tape from the remaining three ZIF connectorsconnectors, then use your fingernail or a spudger to lift the hinged retainer clips on the ZIF connectors and slide the cables out from each.
[* icon_noteicon_reminder] The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
