Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
  • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
  • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
  • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
Hier Übersetzung einfügen
