Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver. When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet. Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
  • Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
  • When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet.
  • Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
Hier Übersetzung einfügen
