Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 2
Use this code *#0*# to enter the phone into the test menu. From this menu you can run tests for vibration, RGB colors, touch-screen, vibration, loudspeaker output, camera, sensor check and so on. From this menu you can run tests for vibration, RGB colors, touch-screen, vibration, loudspeaker output, camera, sensor check and so on.
HIDDEN TEST MENU
  • Use this code *#0*# to enter the phone into the test menu.
  • From this menu you can run tests for vibration, RGB colors, touch-screen, vibration, loudspeaker output, camera, sensor check and so on.
Gib den Code *#0*# ein, um ins Testmenü zu gelangen.
Hier kannst du Tests für Vibration, RGB Farben, Touchscreen, Lautsprecherausgang, Kamera, Sensoren usw. durchführen.
