Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Be careful of LCD connector on the underside of the board through all of these steps (see green). Separate the logic board from front display. Apply heat to the front glass to loosen the adhesive, using a prying tool to separate the board. Be careful and move slowly, it is very strong. Be careful to remove the display first from the right side as there are clips along the left side.
Logic Board
  • Be careful of LCD connector on the underside of the board through all of these steps (see green).
  • Separate the logic board from front display. Apply heat to the front glass to loosen the adhesive, using a prying tool to separate the board. Be careful and move slowly, it is very strong.
  • Be careful to remove the display first from the right side as there are clips along the left side.
  • Ensure not to damage the LCD cable, remove once accessible by releasing the brown clasp from indicated side.
Hier Übersetzung einfügen
