Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 17 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Remove the cover from the Game Pak slot before continuing. Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite. Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
  • Remove the cover from the Game Pak slot before continuing.
  • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
  • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
  • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Setze die Kante eines Spudgers zwischen das oberen und unteren Gehäuseteil in der Nähe der oberen rechten Ecke des DS Lite.
Schiebe den Spudger vorsichtig die rechte Seite des DS Lite entlang, dabei öffnet sich ein Spalt.
Schiebe den Spudger weiter um die Seiten des DS Lite bis ein Großteil des Gehäuses getrennt ist.
+[* icon_note] Remove the cover from the Game Pak slot before continuing.
[* black] Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
[* black] Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
[* black] Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
