Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame Using the second spudger, slowly work your way around the perimeter of the device Listen for clicking sounds as you are prying the back cover away from the frame
  • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
  • Using the second spudger, slowly work your way around the perimeter of the device
  • Listen for clicking sounds as you are prying the back cover away from the frame
  • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
Verwende den flachen und den gebogenen Spudger (metal spudger) als Keil zwischen dem Akkudeckel und dem Gehäuserahmen.
Wandere mit dem zweiten Spudger rundum um das Gehäuse.
Achte auf die Klickgeräusche während du den Deckel vom Gehäuse trennst.
Wenn der Deckel fast vollständig entfernt ist, verwende den Saugnapf, um den Deckel abzuheben, ohne ihn zu zerkratzen.
[* black] Using the flat [product|IF145-012|metal spudger] and curved metal spudger, make a wedge between the plastic back cover and the inner frame
[* black] Using the second spudger, slowly work your way around the perimeter of the device
-[* black] Check for clicking sounds as you are prying the back cover away from the frame
+ [* icon_note] Listen for clicking sounds as you are prying the back cover away from the frame
[* black] As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
