Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 18
Desolder the two solder joints and the 30 pins. To desolder the solder joint, place a copper desoldering braid on top of the existing solder and press down on the braid with the soldering iron. Once the solder melts and flows into the braid, remove the braid from the pad.
  • Desolder the two solder joints and the 30 pins.
  • To desolder the solder joint, place a copper desoldering braid on top of the existing solder and press down on the braid with the soldering iron.
  • Once the solder melts and flows into the braid, remove the braid from the pad.
  • Process may need to be repeated two or three times to ensure complete removal of all solder.
  • DO NOT get solder on the highlighted gold ring, as you will not be able to remove it.
  • Repeat this same process for the other solder joint and all 30 pins.
Hier Übersetzung einfügen
