Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5
Begin removal of the battery circuitry. Use the flat end of a spudger to begin lifting against the metal tab of the top edge of the circuit board unit. When lifted enough, use the pointed end of the spudger to lift the remaining distance.  This is accomplished by inserting the pointed end of the spudger into the hole in the circuit board unit located at the opposite end of the charging port.
  • Begin removal of the battery circuitry.
  • Use the flat end of a spudger to begin lifting against the metal tab of the top edge of the circuit board unit.
  • When lifted enough, use the pointed end of the spudger to lift the remaining distance. This is accomplished by inserting the pointed end of the spudger into the hole in the circuit board unit located at the opposite end of the charging port.
Hier Übersetzung einfügen
