Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
Remove the four screws located in the corners of the metal bracket. Three of the four screws are the same size. The exception is the bottom left screw, which is significantly shorter. Make sure to put the short screw where it belongs when re-assembling. Three of the four screws are the same size. The exception is the bottom left screw, which is significantly shorter. Make sure to put the short screw where it belongs when re-assembling.
  • Remove the four screws located in the corners of the metal bracket.
  • Three of the four screws are the same size. The exception is the bottom left screw, which is significantly shorter. Make sure to put the short screw where it belongs when re-assembling.
Hier Übersetzung einfügen
