Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device. The cable is attached with an adhesive. These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  • Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
  • The cable is attached with an adhesive.
  • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
Hier Übersetzung einfügen
