Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
Solder the wires together. Put a little bit of solder on the tip of the iron. Hold the iron to the wire, and add the solder to the joint. When the wire gets hot enough, the solder will melt and suck itself into the wire.
  • Solder the wires together.
  • Put a little bit of solder on the tip of the iron.
  • Hold the iron to the wire, and add the solder to the joint. When the wire gets hot enough, the solder will melt and suck itself into the wire.
  • Add enough solder and move the iron around enough to make the entire joint silver colored.
  • Once the wire is cool to the touch slide the heat shrink so it covers the joint.
  • If you try to slide the heat shrink over the joint too quickly then the heat from soldering can cause the heat shrink to shrink down, making it difficult to slide it all the way over the joint.
Hier Übersetzung einfügen
