Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 8 übersetzen
Schritt 8
Wrap up the entire thing in electrical tape. If you have a really big section of heat shrink tubing that will fit over the entire joint you can use that as well. The string got cut at this point because there wasn't room to put it all back inside
  • Wrap up the entire thing in electrical tape.
  • If you have a really big section of heat shrink tubing that will fit over the entire joint you can use that as well.
  • The string got cut at this point because there wasn't room to put it all back inside
  • Again, wrap the wire with at least two layers.
  • The better you wrap this the more durable your repair will be.
Hier Übersetzung einfügen
