Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool: Front-facing camera connector.
  • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
  • Front-facing camera connector.
  • Rear-facing camera connector.
  • Digitizer connector.
  • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
Hier Übersetzung einfügen
