Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera. Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
  • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
  • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
  • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
Hier Übersetzung einfügen
