Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 8
Remove the motherboard from the panel carefully.  Use the pry tool as a lever from the top of the panel and lift if from that side. Remove the motherboard from the panel carefully.  Use the pry tool as a lever from the top of the panel and lift if from that side. Remove the motherboard from the panel carefully.  Use the pry tool as a lever from the top of the panel and lift if from that side.
  • Remove the motherboard from the panel carefully. Use the pry tool as a lever from the top of the panel and lift if from that side.
Hier Übersetzung einfügen
