Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
The following steps are only necessary if your replacement Wii DVD drive does not include the four rubber grommets along the front and rear of the DVD drive housing. Insert the tip of a long, skinny screwdriver into the hole in the center of the first grommet on the rear of the DVD drive housing. Pull the grommet straight away from the DVD drive housing until it is free.
  • The following steps are only necessary if your replacement Wii DVD drive does not include the four rubber grommets along the front and rear of the DVD drive housing.
  • Insert the tip of a long, skinny screwdriver into the hole in the center of the first grommet on the rear of the DVD drive housing.
  • Pull the grommet straight away from the DVD drive housing until it is free.
Die folgenden Schritte sind nur notwendig wenn dein Austausch-DVD-Laufwerk nicht mit den vier Gummitüllen vorne und hinten am Laufwerksgehäuse ausgeliefert wurde.
Setze die Spitze eines langen dünnen Schraubendrehers in das Loch in der Mitte der ersten Tülle hinten am Laufwerksgehäuse.
Ziehe die Tülle gerade aus dem Laufwerksgehäuse heraus.
