Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Set the DVD drive on its side, with the two rubber grommets along the front of the drive facing you. Insert the end of the skinny screwdriver into the hole in the center of the lower rubber grommet along the front of the DVD drive housing.
  • Set the DVD drive on its side, with the two rubber grommets along the front of the drive facing you.
  • Insert the end of the skinny screwdriver into the hole in the center of the lower rubber grommet along the front of the DVD drive housing.
  • Pull the screwdriver straight up until the grommet is free.
Lege das Laufwerk auf die Seite so dass die beiden vorderen Tüllen zu dir zeigen.
Setze den Schraubendreher in das Loch in der Mitte einer der Tüllen.
Ziehe den Schraubendreher gerade nach oben, bis die Tülle frei kommt.
