Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 6
Rotate the top of the device towards you so that the audio jack appears on the right side of the device. The audio jack will have a small symbol of headphones next to a small 3.5mm diameter hole. Wedge the plastic opening tool between  where the front and back case panels meet near the audio jack.
  • Rotate the top of the device towards you so that the audio jack appears on the right side of the device.
  • The audio jack will have a small symbol of headphones next to a small 3.5mm diameter hole.
  • Wedge the plastic opening tool between where the front and back case panels meet near the audio jack.
  • Pry the device open using moderate force until you hear a clicking sound. This is the sound of the clips unlocking.
  • Move along the perimeter of the entire device using the same prying motion to gradually separate the front and back panels.
  • Once the edges are open return to the same starting position next to the audio jack.
  • During this step, you may crack some parts of the case. Gently pry around the speakers, audio jack and charging cable ports to reduce this damage.
Hier Übersetzung einfügen
