Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
You do not need to remove the motherboard in order to remove the battery as the photos may indicate. Work the spudger underneath the battery as shown and pry the battery away from the phone case. The battery is attached to the case with adhesive, so a bit of force is required during removal.
  • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
  • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
  • The battery is attached to the case with adhesive, so a bit of force is required during removal.
Hier Übersetzung einfügen
