Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver. Gently remove the motherboard by using a plastic opening tool to pry it out of the housing. Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
  • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
  • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
Hier Übersetzung einfügen
