Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner. Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
  • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
  • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
  • Adhesive on the back side of the battery holds the internal components to the front case.
  • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
Hier Übersetzung einfügen
