Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 10 übersetzen
Schritt 10
Apply a heat gun or iOpener to front of screen to allow it to warm up the glue. Use opening tool and work your way around the front of the screen. You may have to alternate applying the heat and prying to get it loose enough to separate. Be careful not overdo the heat. Use a low temperature and take your time to separate the screen.
Remove front screen
  • Apply a heat gun or iOpener to front of screen to allow it to warm up the glue.
  • Use opening tool and work your way around the front of the screen. You may have to alternate applying the heat and prying to get it loose enough to separate.
  • Be careful not overdo the heat. Use a low temperature and take your time to separate the screen.
  • Clean the black backing off of any glass still sticking to it. Mine had a lot so I had to scrape for awhile to get all the little pieces off to have a clean surface to apply the new replacement screen.
  • Apply new screen to black backing.
Hier Übersetzung einfügen
