Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Remove screw in top left corner. Remove screws on motherboard cover. Pull up on the cover to remove it.
  • Remove screw in top left corner.
  • Remove screws on motherboard cover.
  • Pull up on the cover to remove it.
  • You can use a plastic opener if it is hard to get your fingers under the cover's edges.
  • Do not pull hard on the cover, as there are two ribbon cables under the cover connected to the motherboard.
Hier Übersetzung einfügen
