Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Rotate it so the display is on your right and the keyboard is on your left. Lift the switch cover firmly but slowly so you do not snap it. Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
  • Rotate it so the display is on your right and the keyboard is on your left.
  • Lift the switch cover firmly but slowly so you do not snap it.
  • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
  • The switch cover should easily separate from the laptop as you run the spudger through.
Hier Übersetzung einfügen
