Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
Now is time to test the phone. If the LCD is OK you can order only a touch screen, if no, then you need display assembly - touch screen & LCD With a plastic pick gently scrape the glue.
  • Now is time to test the phone.
  • If the LCD is OK you can order only a touch screen, if no, then you need display assembly - touch screen & LCD
  • With a plastic pick gently scrape the glue.
  • With a cloth and isopropyl alcohol clean the LCD.
  • Don't use a lot of alcohol. if the liquid passes behind the LCD, will appear spots that you can't remove.
Hier Übersetzung einfügen
