Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Schritt 1 übersetzen
Schritt 1
Disconnect the nine visible ribbon cables/ZIF connectors by flipping the black bars up and pulling the ribbon straight out of the connector.
Disconnect two more cables in the upper left corner of the board, hidden behind the visible cables.
- | [* icon_caution] You may need to use tweezers and a spudger to disconnect some of the ribbon cables so they do not break. |
+ | [* icon_caution] You may need to use [product|IF145-020|tweezers] and a spudger to disconnect some of the ribbon cables so they do not break. |
[* red] Disconnect the nine visible ribbon cables/ZIF connectors by flipping the black bars up and pulling the ribbon straight out of the connector. | |
[* black] Disconnect two more cables in the upper left corner of the board, hidden behind the visible cables. | |
[* icon_note] Learn more about disconnecting ZIF connectors [guide|25629|here.] |
