Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
Turn the computer upright and lift the screen. Carefully use a spudger to pry the plastic keyboard cover from the base. When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
  • Turn the computer upright and lift the screen.
  • Carefully use a spudger to pry the plastic keyboard cover from the base.
  • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
  • Work the spudger around the cover to release the clips attaching the cover to the base.
  • Be patient when removing the cover, as there are many clips and it may take some time.
Hier Übersetzung einfügen
