Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3
Stand the LCD panel on its TOP edge and locate the lock tabs along the BOTTOM edge.  There are 5 along the length of the bottom edge Use a flat blade driver or metal spudger to Gently pop the bezel off the lock tabs. Locate the lock tabs on either side of the LCD panel.  There are 2 on each side
  • Stand the LCD panel on its TOP edge and locate the lock tabs along the BOTTOM edge. There are 5 along the length of the bottom edge
  • Use a flat blade driver or metal spudger to Gently pop the bezel off the lock tabs.
  • Locate the lock tabs on either side of the LCD panel. There are 2 on each side
  • Use a flat blade driver or metal spudger to Gently pop the bezel off the side lock tabs.
Hier Übersetzung einfügen
