Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface. Be careful not to sever the wire connecting the nfc chip to the inside of the device. Gently slide the NFC chip into the device through the slot that the wire comes from.
  • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
  • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
  • Gently slide the NFC chip into the device through the slot that the wire comes from.
Hier Übersetzung einfügen
