Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 7 übersetzen
Schritt 7
Carefully insert the metal spudger between  the battery and its metal housing and then slowly pry the two apart. Be careful when prying the two apart as to not bend the outer edges of the metal housing because this will make it a lot more difficult to put it back into the phone. Be careful when prying the two apart as to not bend the outer edges of the metal housing because this will make it a lot more difficult to put it back into the phone.
  • Carefully insert the metal spudger between the battery and its metal housing and then slowly pry the two apart.
  • Be careful when prying the two apart as to not bend the outer edges of the metal housing because this will make it a lot more difficult to put it back into the phone.
Setze den Metallhebel vorsichtig zwischen die Batterie und das Metallgehäuse und trenne die beiden Bauteile voneinander (sie sind leicht verklebt).
Sei vorsichtig, beim Trennen der beiden Hälften, um die Außenkanten des Metallgehäuses nicht zu verbiegen, da es dadurch viel schwieriger wird, es wieder in das Telefon einzusetzen (am besten flach auf den Tisch legen).
