Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Schritt 3 übersetzen
Schritt 3
Using a heat gun, apply slow and even heat to the edges of the back panel.
While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the back panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the back panel.
[* icon_caution] Put on heat-resistant gloves and place the phone on a surface that will not catch fire or melt. |
[* black] Using a heat gun, [* icon_caution] [* black] While heating the [* black] Carefully detach the [* black] Once most of the edges are separated from the device, attach a suction cup to the back panel. |
