Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
Press the suction cup to the back panel to secure it. With the help of the suction cup, pull up on the panel to completely detach it from the device. Use the suction cup to safely remove the panel from the device. As you work around the panel's edges, the lingering heat may cause the remaining adhesive to reattach the panel to the device, be sure to lift the back panel before the glue has time to set back.
  • Press the suction cup to the back panel to secure it.
  • With the help of the suction cup, pull up on the panel to completely detach it from the device.
  • Use the suction cup to safely remove the panel from the device. As you work around the panel's edges, the lingering heat may cause the remaining adhesive to reattach the panel to the device, be sure to lift the back panel before the glue has time to set back.
Drücke den Saugnapf an der Scheibe an, bis er gut festsitzt.
Ziehe mit Hilfe des Saugnapfs die Rückabdeckung vom Gerät ab.
Der Saugnapf hilft dir beim Ablösen der Abdeckung. Passe dabei auf, dass sie sich durch die vorhandene Restwärme nicht wieder verklebt.
[* black] Press the suction cup to the rearback panel to secure it.
[* black] With the help of the suction cup, pull up on the panel to completely detach it from the device.
[* icon_note] Use the suction cup to safely remove the panel from the device. As you work around the panel's edges, the lingering heat may cause the remaining adhesive to reattach the panel to the devicedevice, be sure to lift the back panel before the glue has time to set back.
