Zum Hauptinhalt wechseln
Nexus 5X Rückkamera austauschen
Englisch
Deutsch
Schritt 3
Nexus 5X Rear-Facing Camera Replacement: Schritt 0, Bild 1 von 2 Nexus 5X Rear-Facing Camera Replacement: Schritt 0, Bild 2 von 2
  • Apply the flat end of a spudger to the left side of the rear-facing camera and carefully lever it out of its recess.
Nutze einen flachen Spudger, um die Kamera hochzuheben und vom Smartphone zu lösen.
Die Kamera ist festgeklebt. Wenn du Probleme hast sie zu lösen, nutze einen iOpnener, um den Kleber zu lösen.
-[* black] Using a single flat spudger lift the camera and detach it from the phone.
- [* icon_note] There is an adhesive located underneath this camera. If you are having difficulty removing it, use the [product|IF145-198-4|iOpener] kit to heat the phone up and help loosen the adhesive.
+[* black] Apply the flat end of a spudger to the left side of the rear-facing camera and carefully lever it out of its recess.
