Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Schritt 1 übersetzen
Schritt 1
Using a PH000 screwdriver, remove the following seven screws circled with red and orange:
Four (longer) PH000 screws
Three shorter PH000 screws
Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
There are two clips near the bottom, right above the battery, so start by prying on the bottom edge of the plate.
[* black] Using a PH000 screwdriver, remove the following seven [* red] Four (longer) [* orange] Three shorter |
[* black] Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off. |
[* black] There are two clips near the bottom, right above |
