Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera.  It should slide forward and unlock the clips holding it in place. Then it should be easy to simply lift the rear face plate up and remove it.
  • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
  • Then it should be easy to simply lift the rear face plate up and remove it.
Hier Übersetzung einfügen
