Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
If your replacement sensor cable has an extra tab, you'll need to carefully cut it off. You won't need this tab—it's used for parts testing. Use scissors to cut the cable right below the yellow plastic tabs. Use scissors to cut the cable right below the yellow plastic tabs.
  • If your replacement sensor cable has an extra tab, you'll need to carefully cut it off. You won't need this tab—it's used for parts testing.
  • Use scissors to cut the cable right below the yellow plastic tabs.
Hier Übersetzung einfügen
+[* icon_note] If your replacement sensor cable has an extra tab, you'll need to carefully cut it off. You won't need this tab—it's used for parts testing.
+ [* red] Use scissors to cut the cable right below the yellow plastic tabs.
