Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 5
Turn the oil filter counterclockwise (when looking up at it) to remove it. If your filter is on too tight to loosen by hand, you may need to use an oil filter wrench or belt wrench to remove it. Oil will begin to run down the sides of the oil filter. It is up to your discretion to either let it drain slowly this way or take the filter off quickly. Keep in mind that no matter what, the filter itself will still have oil in it that must be drained.
Removing the Old Oil Filter
  • Turn the oil filter counterclockwise (when looking up at it) to remove it.
  • If your filter is on too tight to loosen by hand, you may need to use an oil filter wrench or belt wrench to remove it.
  • Oil will begin to run down the sides of the oil filter. It is up to your discretion to either let it drain slowly this way or take the filter off quickly. Keep in mind that no matter what, the filter itself will still have oil in it that must be drained.
  • Set the old filter in your oil drain pan with the gasket facing down to allow the oil to drain out of it.
  • Once the oil filter is removed carefully inspect the old filter and the filter seating surface on the engine for the gasket from the old filter. Sometimes this will remain in place and is a guaranteed major leak if not removed prior to installing the new filter.
  • Let the rest of the oil from the engine drain and collect in the oil drain pan.
Drehen den Ölfilter gegen den Uhrzeigersinn (wenn du von unten nach oben schaust), um diesen zu entfernen.
Es kann vorkommen, dass der Filter so fest sitzt, dass du einen Ölfilterschlüssel oder Riemenschlüssel verwenden musst.
Öl wird an den Seiten des Ölfilters austreten. Es liegt in deinem Ermessen, es langsam ablaufen zu lassen oder den Filter schnell zu entfernen. Bedenke, dass der Filter selbst immer noch Öl enthält, das abgelassen werden muss.
Setze den alten Ölfilter mit der Dichtung nach unten in deinen alten Auffangbehälter, damit das Öl auslaufen kann.
Stelle sicher, dass die Dichtung des alten Ölfilters von der Aufsitzfläche am Motor entfernt ist. Wird die alte Dichtung nicht entfernt, kommt es höchstwahrscheinlich zu einem Leck, durch welches viel Öl austreten wird.
Lasse den Rest des Öls aus dem Motor ablaufen und sammle ihn im Auffangbehälter.
